ArcGIS.Desktop.Mapping Namespace / Animation Class / ScaleDuration Method / ScaleDuration(Double) Method
The factor to scale by.
Example
    Adjust the length of the animation by a given scale factor.
    Syntax
    public void ScaleDuration(
       double factor
    Public Overloads Sub ScaleDuration( _
       ByVal factor As Double _
    Parameters
    factor
    Example
    Set Animation Length
      var animation = mapView.Map.Animation;
      var duration = animation.Duration;
      if (duration == TimeSpan.Zero)
        return;
      var factor = length.TotalSeconds / duration.TotalSeconds;
      animation.ScaleDuration(factor);
    Requirements
