ArcGIS.Desktop.Mapping Namespace / Animation Class / ScaleDuration Method / ScaleDuration(TimeSpan,TimeSpan,Double) Method
The start time to scale.
The end time to scale.
The factor to scale by.
Example
    Adjust the length of the track by a given scale factor.
    Syntax
    public void ScaleDuration(
       TimeSpan start,
       TimeSpan end,
       double factor
    Public Overloads Sub ScaleDuration( _
       ByVal start As TimeSpan, _
       ByVal end As TimeSpan, _
       ByVal factor As Double _
    Parameters
    start
    end
    factor
    Example
    Scale Animation
      var animation = mapView.Map.Animation;
      var duration = animation.Duration;
      if (duration == TimeSpan.Zero || duration <= afterTime)
        // Nothing to scale, leave
      var factor = length.TotalSeconds / (duration.TotalSeconds - afterTime.TotalSeconds);
      animation.ScaleDuration(afterTime, duration, factor);
    Requirements
