ArcGIS.Desktop.Mapping Namespace / Animation Class / NumberOfFrames Property
Example
    Gets the total number of frames in the animation.
    Syntax
    public long NumberOfFrames {get;}
    Public ReadOnly Property NumberOfFrames As Long
    Example
    Interpolate Camera
      //Return the collection representing the camera for each frame in animation.
      await QueuedTask.Run(() =>
        var animation = mapView.Map.Animation;
        var cameras = new List<Camera>();
        //We will use ticks here rather than milliseconds to get the highest precision possible.
        var ticksPerFrame = Convert.ToInt64(animation.Duration.Ticks / (animation.NumberOfFrames - 1));
        for (int i = 0; i < animation.NumberOfFrames; i++)
          var time = TimeSpan.FromTicks(i * ticksPerFrame);
          //Because of rounding for ticks the last calculated time may be greater than the duration.
          if (time > animation.Duration)
            time = animation.Duration;
          cameras.Add(mapView.Animation.GetCameraAtTime(time));
        // Use cameras
    Interpolate Time
      //Return the collection representing the map time for each frame in animation.
        var timeRanges = new List<TimeRange>();
          timeRanges.Add(mapView.Animation.GetCurrentTimeAtTime(time));
        // Use timeRanges;
    Interpolate Range
        var ranges = new List<ArcGIS.Desktop.Mapping.Range>();
          //Because of rounding for ticks the last calculated time may be greeting than the duration.
          ranges.Add(mapView.Animation.GetCurrentRangeAtTime(time));
        // Use ranges
    Requirements
