ArcGIS.Desktop.Mapping Namespace / BasicFeatureLayer Class / GetTable Method
Example
    GetTable Method (BasicFeatureLayer)
    Returns the underlying feature class as Table type. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetTable() As Table
    public Table GetTable()
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    You may want to cast it to FeatureClass.
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Table in either a using statement or a finally block.
    Example
    Obtaining Geodatabase from FeatureLayer
      await QueuedTask.Run(() =>
        IEnumerable<Layer> layers =
          MapView.Active.Map.Layers.Where(layer => layer is FeatureLayer);
        foreach (FeatureLayer featureLayer in layers)
          using (Table table = featureLayer.GetTable())
          using (Datastore datastore = table.GetDatastore())
            if (datastore is UnknownDatastore)
              continue;
            Geodatabase geodatabase = datastore as Geodatabase;
    Gets the count of a Table or FeatureClass
      //Must be called within QueuedTask.Run()
      void GetCount(FeatureLayer featureLayer)
        // Row count in a Table
        Table table = featureLayer.GetTable();
        long count = table.GetCount();
        // Feature count in a FeatureClass
        FeatureLayer lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault();
        FeatureClass featureClass = lyr.GetFeatureClass();
        count = featureClass.GetCount();
    Get the Annotation Text Graphic
      // Note: QueuedTask is required to access the AnnotationFeature
        using var table = annotationLayer.GetTable();
        using var rc = table.Search();
        rc.MoveNext();
        using var af = rc.Current as AnnotationFeature;
        var graphic = af.GetGraphic();
        var textGraphic = graphic as CIMTextGraphic;
        //Note:
        //var outline_geom = af.GetGraphicOutline();
        //gets the anno text outline geometry...
    Requirements
