ArcGIS.Desktop.Mapping Namespace / BasicFeatureLayer Class / SetDefinitionQuery Method
A where clause that conforms to SQL standard to filter records.
Example
    SetDefinitionQuery Method (BasicFeatureLayer)
    Sets the where clause of the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function SetDefinitionQuery( _
       ByVal whereClause As String _
    ) As DefinitionQuery
    public DefinitionQuery SetDefinitionQuery(
       string whereClause
    Parameters
    whereClause
    Return Value
    A DefinitionQuery object.
    Exceptions
    ExceptionDescription
    This method cannot be called if the feature layer is a member of SubtypeGroupLayer. Use the IsSubtypeLayer property to determine if the feature layer is a member of a SubtypeGroupLayer.
    Remarks
    If the whereClause is null or empty string, then the active query definition is removed and the layer no longer has an active definition query.Where there is an active definition query, this function updates the where clause of tha definition query with the whereClause you pass in.If the whereClause is non-null, and there is no active definition query, a new definition query with the specified where clause is created and becomes the active definition query. An auto generated name gets assigned. All other definition queries that are not active remain unchanged.Use SetActiveDefinitionQuery to activate or deactivate any existing definition query.
    Example
    Apply A Definition Query Filter to a Feature Layer
        var us_parks = map.GetLayersAsFlattenedList()
      .OfType<FeatureLayer>().First(l => l.Name == "USNationalParks");
        //Note: needs to be called on the MCT
        var def_query = new DefinitionQuery("CaliforniaParks",
                          "STATE_ABBR = 'CA'");
        us_parks.InsertDefinitionQuery(def_query);
        us_parks.SetDefinitionQuery("STATE_ABBR = 'CA'");
        //Set it active
        us_parks.SetActiveDefinitionQuery(def_query.Name);
        //or....also - set it active when it is inserted
        //us_parks.InsertDefinitionQuery(def_query, true);
    Apply A Definition Query Filter to a Feature Layer Option 2
        //inserts a new definition query and makes it active
        //it will be assigned a unique name
    Requirements
