ArcGIS.Desktop.Mapping Namespace / BasicFeatureLayer Class / SetEditable Method
A boolean to toggle editability.
Example
    SetEditable Method (BasicFeatureLayer)
    Enables or disables editing on a basic feature layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetEditable( _
       ByVal isEditable As Boolean _
    public void SetEditable(
       bool isEditable
    Parameters
    isEditable
    Exceptions
    ExceptionDescription
    Remarks
    Just setting it true will not make a basic feature layer editable unless you have permission to edit on data source level.
    Example
    Change layer visibility, editability, snappability
        if (!layer.IsVisible)
            layer.SetVisibility(true);
        if (layer is FeatureLayer featureLayerToChange)
            if (!featureLayer.IsEditable)
                featureLayer.SetEditable(true);
            if (!featureLayer.IsSnappable)
                featureLayer.SetSnappable(true);
    Requirements
