ArcGIS.Desktop.Workflow.Client.Models Namespace / IJobsManager Interface
Members Example
    Provides access to the jobs within Workflow Manager.
    Object Model
    IJobsManager InterfaceJobStatistics ClassJob ClassSearchResult Class
    Syntax
    Public Interface IJobsManager
    public interface IJobsManager
    Example
    Get the job Id associated with the active map view
      // Get the job Id associated with the active map view
      var jobManager = WorkflowClientModule.JobsManager;
      jobId = jobManager.GetJobId();
      // Use the jobId to identify the job associated with the active map view
    Get the job Id associated with a map
      // Get the job Id associated with a map
      jobId = jobManager.GetJobId(mapUri);
      // Use the jobId to identify the job associated with the map
    Get a job
      // Note: QueuedTask is required to call Workflow Manager API methods
      // GetJob returns an existing job
      try
        var job = jobManager.GetJob(jobId);
        // Do something with the job
      catch (NotConnectedException)
        // Not connected to Workflow Manager server, do some error handling
      catch (Exception)
        // Some other exception occurred, do some error handling
      // Use the job object
    Search for jobs using a detailed query
      var search = new SearchQuery()
        // Search for all open high priority jobs assigned to users
        Q = "closed=0 AND assignedType='User' AND priority='High'",
        Fields = ["jobId", "jobName", "assignedTo", "dueDate"],
        // Sort by job assignment in ascending order and due date in descending order
        SortFields =
          new SortField() { FieldName = "assignedTo", SortOrder = SortOrder.Asc },
          new SortField() { FieldName = "dueDate", SortOrder = SortOrder.Desc }
      var searchResults = jobManager.SearchJobs(search);
      var fields = searchResults.Fields;
      var results = searchResults.Results;
    Search for jobs using a detailed query with an arcade expression
        // Search for jobs assigned to the current user using the arcade expression '$currentUser'
        Q = "\"assignedType='User' AND closed=0 AND assignedTo='\" + $currentUser + \"' \"",
        // Sort by job name in ascending order
        SortFields = [new SortField() { FieldName = "jobName", SortOrder = SortOrder.Asc }]
    Search for jobs using a simple string
      var search = new SearchQuery() { Search = "My Search String" };
      // Use the fields and results collections
    Get statistics for jobs
      var query = new JobStatisticsQuery()
        // Search for open jobs assigned to users
        Q = "\"assignedType='User' AND closed=0 \""
      var results = jobManager.CalculateJobStatistics(query);
      var totalJobs = results.Total;
    Run steps on a job
      jobManager.RunSteps(jobId);
    Run specific steps on a job
      // Specify specific current steps in a job to run
      var stepIds = new List<string> { "step12345", "step67890" };
      jobManager.RunSteps(jobId, stepIds);
    Stop running steps on a job
      // Stop the current steps in the job with the given id.
      jobManager.StopSteps(jobId);
    Stop specific running steps on a job
      // Specify specific running steps in a job to stop
      List<string> stepIds = ["step12345", "step67890"];
      jobManager.StopSteps(jobId, stepIds);
    Finish steps on a job
      // Finish the current steps in the job with the given id.
      jobManager.FinishSteps(jobId);
    Finish specific steps on a job
      jobManager.FinishSteps(jobId, stepIds);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
