Public Class ColorFactory Implements IColorFactory
public class ColorFactory : IColorFactory
//Note: Must be on QueuedTask.Run
//Build geometry
Coordinate2D center = new Coordinate2D(2, 2.75);
var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45,
ArcOrientation.ArcClockwise);
var ellipse = eabElp.ToSegment();
//Set symbology, create and add element to layout
CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
ColorFactory.Instance.GreenRGB, 2.0,
SimpleLineStyle.Dot);
CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical,
outline);
var poly = PolygonBuilderEx.CreatePolygon(
PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
var elpElm = ElementFactory.Instance.CreateGraphicElement(
layout, poly, ellipseSym, "New Ellipse");
/// <summary> /// Create a mesh symbol that can be applied to a multi-patch feature layer. /// A mesh symbol is a CIMMeshSymbol object. Define an array of CIMSymbolLayers which contains a CIMMaterialSymbol layer with the specified properties such as Color, etc. /// Assign this array of CIMSymbolLayers to the CIMMeshSymbol. ///  /// </summary> { //Note: Run withing QueuedTask CIMSymbolLayer[] materialSymbolLayer = { new CIMMaterialSymbolLayer() { Color = ColorFactory.Instance.CreateRGBColor(230,152,0), MaterialMode = MaterialMode.Multiply } }; var meshMaterialFillSymbol = new CIMMeshSymbol() { SymbolLayers = materialSymbolLayer }; }
/// <summary> /// Create a polygon symbol with a dash dot fill. <br/> ///  /// </summary> { //Note: Run withing QueuedTask var trans = 50.0;//semi transparent CIMStroke outline = SymbolFactory.Instance.ConstructStroke(CIMColor.CreateRGBColor(0, 0, 0, trans), 2.0, SimpleLineStyle.Solid); //Stroke for the fill var dashDot = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 1.0, SimpleLineStyle.DashDotDot); //Mimic cross hatch CIMFill[] solidColorHatch = { new CIMHatchFill() { Enable = true, Rotation = 0.0, Separation = 2.5, LineSymbol = new CIMLineSymbol(){SymbolLayers = new CIMSymbolLayer[1] {dashDot } } }, new CIMSolidFill() { Enable = true, Color = ColorFactory.Instance.CreateRGBColor(255, 255, 0) }, }; List<CIMSymbolLayer> symbolLayers = [outline, .. solidColorHatch]; //This is the polygon symbol with a dash dot fill CIMPolygonSymbol dashDotFillPolygon = new CIMPolygonSymbol() { SymbolLayers = symbolLayers.ToArray() }; //To apply the symbol to a polygon feature layer //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer; //renderer.Symbol = dashDotFillPolygon.MakeSymbolReference(); //theLayer.SetRenderer(renderer); }
System.Object
ArcGIS.Desktop.Mapping.ColorFactory
