var featureLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(); // is the layer snappable? bool isSnappable = featureLayer.IsSnappable; // set snappability for a specific layer - needs to run on the MCT await QueuedTask.Run(() => { // use an extension method featureLayer.SetSnappable(true); // or use the CIM directly //var layerDef = fLayer.GetDefinition() as ArcGIS.Core.CIM.CIMGeoFeatureLayerBase; //layerDef.Snappable = true; //fLayer.SetDefinition(layerDef); }); // turn all layers snappability off var layerList = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>(); await QueuedTask.Run(() => { foreach (var layer in layerList) { layer.SetSnappable(false); } });
if (!layer.IsVisible)
layer.SetVisibility(true);
if (layer is FeatureLayer featureLayerToChange)
if (!featureLayer.IsEditable)
featureLayer.SetEditable(true);
if (!featureLayer.IsSnappable)
