ArcGIS.Desktop.Mapping Namespace / FieldDescription Class / Name Property
Example
    Name Property (FieldDescription)
    Gets the name of a field.
    Syntax
    public string Name {get;}
    Public ReadOnly Property Name As String
    Example
    Get or set the Active Field
      // get active field, active field name
      var activeFieldIdx = tableView.ActiveFieldIndex;
      var fldDesc = tableView.GetField(activeFieldIdx);
      var fldName = fldDesc.Name;
      // set active field by name
      tableView.SetActiveField("STATE_NAME");
      // or set active field by index
      tableView.SetActiveField(3);
    Create a histogram for every field of type Double
      // For more information on the chart CIM specification:
      // https://github.com/Esri/cim-spec/blob/main/docs/v3/CIMCharts.md
      var lyrDefHistogram = featureLayer.GetDefinition();
      // Get list names for fields of type Double
      var doubleFields = featureLayer.GetFieldDescriptions().Where(f => f.Type == FieldType.Double).Select(f => f.Name);
      // Create list that will contain all histograms
      var histograms = new List<CIMChart>();
      // Create histogram for each Double field
      foreach (var field in doubleFields)
        // Define histogram CIM properties
        var histogram = new CIMChart
          Name = $"histogram_{field}",
          GeneralProperties = new CIMChartGeneralProperties
            Title = $"Histogram for {field}",
            UseAutomaticTitle = false
          Series =
                  new CIMChartHistogramSeries {
                      UniqueName = "histogramSeries",
                      BinCount = 15,
                      // Specify the number field
                      Fields = new string[] { field },
        histograms.Add(histogram);
      // Add new chart to layer's existing list of charts (if any exist)
      var allChartsHistogram = (lyrDefHistogram == null) ? histograms : lyrDefHistogram.Charts.Concat(histograms);
      // Add CIM chart to layer definition
      lyrDefHistogram.Charts = allChartsHistogram.ToArray();
      featureLayer.SetDefinition(lyrDefHistogram);
    Requirements
