ArcGIS.Desktop.Mapping Namespace / MapFactory Class / CanCreateMapFrom Method
An ArcGIS.Desktop.Core.Item.
    CanCreateMapFrom Method (MapFactory)
    Determines whether a map can be created from an Item.
    Syntax
    public bool CanCreateMapFrom(
       Item item
    Public Function CanCreateMapFrom( _
       ByVal item As Item _
    ) As Boolean
    Parameters
    item
    Return Value
    A boolean indicates that a map can be created from the item.
    Remarks
    You should use this method before passing an item to the MapFactory.CreateMapFromItem() method.
    Requirements
