ArcGIS.Desktop.Mapping Namespace / MapMember Class / GetDataConnection Method
Example
    GetDataConnection Method (MapMember)
    Gets a CIMDataConnection value object. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overridable Function GetDataConnection() As CIMDataConnection
    public virtual CIMDataConnection GetDataConnection()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Reset the URL of a feature service layer
        CIMStandardDataConnection dataConnection = featureLayer.GetDataConnection() as CIMStandardDataConnection;
        dataConnection.WorkspaceConnectionString = @"DATABASE=C:\Data\USNationalParks\USNationalParks.gdb";
        //Note: needs to be called on the MCT
        featureLayer.SetDataConnection(dataConnection);
    Requirements
