ArcGIS.Desktop.Mapping Namespace / MapMember Class / SetDataConnection Method
A CIM data connection value object.
true to make sure dataset exists and of valid data type before replacing the data source e.g. you cannot change a FeatureLayer's data source to a Raster Dataset.
-or-
false to indicate no validation required. It might not already exist. This can be useful for scenarios that require data sources to be updated ahead of the data being created. Note, in these cases, the data would appear broken in the map.
Example
    Updates a MapMember's data source. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetDataConnection( _
       ByVal dataConnection As CIMDataConnection, _
       Optional ByVal validateConnection As Boolean _
    public void SetDataConnection(
       CIMDataConnection dataConnection,
       bool validateConnection
    Parameters
    dataConnection
    validateConnection
    -or-
    Exceptions
    ExceptionDescription
    Example
    Reset the URL of a feature service layer
        CIMStandardDataConnection dataConnection = featureLayer.GetDataConnection() as CIMStandardDataConnection;
        dataConnection.WorkspaceConnectionString = @"DATABASE=C:\Data\USNationalParks\USNationalParks.gdb";
        //Note: needs to be called on the MCT
        featureLayer.SetDataConnection(dataConnection);
    Requirements
