//Return the collection representing the map time for each frame in animation.
// Note: Needs QueuedTask to run
var animation = mapView.Map.Animation;
var ranges = new List<ArcGIS.Desktop.Mapping.Range>();
//We will use ticks here rather than milliseconds to get the highest precision possible.
var ticksPerFrame = Convert.ToInt64(animation.Duration.Ticks / (animation.NumberOfFrames - 1));
for (int i = 0; i < animation.NumberOfFrames; i++)
var time = TimeSpan.FromTicks(i * ticksPerFrame);
//Because of rounding for ticks the last calculated time may be greeting than the duration.
if (time > animation.Duration)
time = animation.Duration;
ranges.Add(mapView.Animation.GetCurrentRangeAtTime(time));
// Use ranges
System.Object
