ArcGIS.Desktop.Mapping Namespace / SnappingOptions Class
Members Example
    Snapping options for a map.
    Object Model
    SnappingOptions ClassCIMColor Class
    Syntax
    Public NotInheritable Class SnappingOptions
    public sealed class SnappingOptions
    Remarks
    The properties for this class represent the options on the snapping options dialog.
    Example
    Snap Options
    var myMap = MapView.Active.Map;
    // Set snapping options via get/set options
    var snapOptions = Snapping.GetOptions(myMap);
    snapOptions.IsSnapToSketchEnabled = true;
    snapOptions.XYTolerance = 100;
    snapOptions.IsZToleranceEnabled = true;
    snapOptions.ZTolerance = 0.6;
    // turn on snap tip display parts
    snapOptions.SnapTipDisplayParts = (int)SnapTipDisplayPart.SnapTipDisplayLayer + (int)SnapTipDisplayPart.SnapTipDisplayType;
    // turn off all snaptips
    // snapOptions.SnapTipDisplayParts = (int)SnapTipDisplayPart.SnapTipDisplayNone;
    // turn on layer display only
    // snapOptions.SnapTipDisplayParts = (int)SnapTipDisplayPart.SnapTipDisplayLayer;
    snapOptions.SnapTipColor = ColorFactory.Instance.RedRGB;
    Snapping.SetOptions(myMap, snapOptions);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.SnappingOptions
    Requirements
