ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructMarker Method / ConstructMarker(CIMColor,Double,SimpleMarkerStyle) Method
ArcGIS.Core.CIM.CIMColor
The size of the marker to construct.
SimpleMarkerStyle
Example
    Constructs a marker of specific color, size and style. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function ConstructMarker( _
       ByVal color As CIMColor, _
       ByVal size As Double, _
       ByVal markerStyle As SimpleMarkerStyle _
    ) As CIMMarker
    Parameters
    color
    size
    markerStyle
    SimpleMarkerStyle
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Example
    How to construct a point symbol from a marker
        CIMMarker marker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.GreenRGB, 8.0, SimpleMarkerStyle.Pushpin);
        CIMPointSymbol pointSymbolFromMarker = SymbolFactory.Instance.ConstructPointSymbol(marker);
    How to construct a multilayer line symbol with circle markers on the line ends
        //Note: Needs QueuedTask to run
        var lineStrokeRed = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 4.0);
        var markerCircle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Circle);
        markerCircle.MarkerPlacement = new CIMMarkerPlacementOnVertices()
            AngleToLine = true,
            PlaceOnEndPoints = true,
            Offset = 0
        var lineSymbolWithCircles = new CIMLineSymbol()
            SymbolLayers = new CIMSymbolLayer[2] { markerCircle, lineStrokeRed }
    How to construct a multilayer line symbol with an arrow head on the end
          var markerTriangle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Triangle);
          markerTriangle.Rotation = -90; // or -90
          markerTriangle.MarkerPlacement = new CIMMarkerPlacementOnLine() { AngleToLine = true, RelativeTo = PlacementOnLineRelativeTo.LineEnd };
          var lineSymbolWithArrow = new CIMLineSymbol()
              SymbolLayers = new CIMSymbolLayer[2] { markerTriangle,
              SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2)
    Modify a point symbol created from a character marker
        //create marker from the Font, char index,size,color
        var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
        var polygonMarker = cimMarker.Symbol;
        //modifying the polygon's outline and fill
        //This is the outline
        polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
        //This is the fill
        polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
        //create a symbol from the marker
        //Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
    Requirements
