ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructMarker Method / ConstructMarker(Int32,String,String) Method
The index of the character from the font.
The font family name of the character marker to construct.
The font style name (Regular, Bold, Italic, etc.) of the character marker to construct.
Example
    Constructs a character marker.
    Syntax
    Public Overloads Function ConstructMarker( _
       ByVal characterIndex As Integer, _
       ByVal fontFamily As String, _
       ByVal fontStyle As String _
    ) As CIMMarker
    Parameters
    characterIndex
    fontFamily
    fontStyle
    Return Value
    Example
    Modify a point symbol created from a character marker
        //create marker from the Font, char index,size,color
        //Note: Needs QueuedTask to run
        var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
        var polygonMarker = cimMarker.Symbol;
        //modifying the polygon's outline and fill
        //This is the outline
        polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
        //This is the fill
        polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
        //create a symbol from the marker
        //Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
    Requirements
