Public Overloads Function ConstructTextSymbol() As CIMTextSymbol
public CIMTextSymbol ConstructTextSymbol()
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run |
//Create a simple point text element and assign basic symbology and text settings.
//Note: Must be on QueuedTask.Run
//Build 2D point geometry
Coordinate2D coord2D = new Coordinate2D(3.5, 10);
//Set symbology, create and add element to layout
CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.RedRGB, 32, "Arial", "Regular");
string textString = "Point text";
//use ElementInfo to set placement properties during create
var elemInfo = new ElementInfo()
Anchor = Anchor.CenterPoint,
Rotation = 45
var ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.PointText, coord2D.ToMapPoint(), sym, textString,
"New Point Text", true, elemInfo);
//Change additional text properties
ptTxtElm.SetX(4.5);
ptTxtElm.SetY(9.5);
//Create rectangle text with background and border symbology.
//Build 2D polygon geometry
List<Coordinate2D> plyCoords = new List<Coordinate2D>();
plyCoords.Add(new Coordinate2D(3.5, 7));
plyCoords.Add(new Coordinate2D(4.5, 7));
plyCoords.Add(new Coordinate2D(4.5, 6.7));
plyCoords.Add(new Coordinate2D(5.5, 6.7));
plyCoords.Add(new Coordinate2D(5.5, 6.1));
plyCoords.Add(new Coordinate2D(3.5, 6.1));
Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
//Also notice how formatting tags are using within the text string.
ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
string text = "Some Text String that is really long and is " +
"<BOL>forced to wrap to other lines</BOL> so that " +
"we can see the effects." as String;
GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
//(Optionally) Modify paragraph border
CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
cimPolyTxtGra.Frame.BorderSymbol.Symbol =
SymbolFactory.Instance.ConstructLineSymbol(
ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
polyTxtElm.SetGraphic(polyTxtGra);
//Build geometry
var elemInfo = new ElementInfo() { Anchor = Anchor.BottomLeftCorner };
GraphicElement ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
//Build geometry
string text = "Some text string that is really long and " +
"<BOL>wraps to other lines</BOL>" +
" so that we can see the effects.";
var ge = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.PolygonParagraph, poly, sym, text,
"New Polygon Text", true);
//Build geometry
Coordinate2D ll = new Coordinate2D(3.5, 4.75);
Coordinate2D ur = new Coordinate2D(5.5, 5.75);
Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
ColorFactory.Instance.WhiteRGB, 10, "Arial", "Regular");
//(Optionally) Modify border and background with 50% transparency
//CIMGraphic recTxtGra = recTxtElm.Graphic;
//CIMParagraphTextGraphic cimRecTxtGra = recTxtGra as CIMParagraphTextGraphic;
//CIMSymbolReference cimRecTxtBorder = cimRecTxtGra.Frame.BorderSymbol;
//CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
// ColorFactory.Instance.BlackRGB, 1.0, SimpleLineStyle.Solid);
//cimRecTxtBorder.Symbol = lineSym;
//CIMSymbolReference cimRecTxtBkgrd = cimRecTxtGra.Frame.BackgroundSymbol;
//CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
// ColorFactory.Instance.GreyRGB, SimpleFillStyle.Solid);
//CIMColor symCol = polySym.GetColor(IElementContainer container);
//symCol.SetAlphaValue(50);
//cimRecTxtBkgrd.Symbol = polySym;
//recTxtElm.SetGraphic(recTxtGra);
var ge = ElementFactory.Instance.CreateTextGraphicElement(layout,
TextType.RectangleParagraph, env, sym, text, "New Rectangle Text");
//Note: Must be on QueuedTask.Run(() => { ...
//Build geometry
Coordinate2D center = new Coordinate2D(4.5, 4);
var eabCir = new EllipticArcBuilderEx(center, 0.5, ArcOrientation.ArcClockwise);
var cir = eabCir.ToSegment();
var poly = PolygonBuilderEx.CreatePolygon(
PolylineBuilderEx.CreatePolyline(cir, AttributeFlags.AllAttributes));
ColorFactory.Instance.GreenRGB, 10, "Arial", "Regular");
string text = "Circle, circle, circle";
GraphicElement cirTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.CircleParagraph, poly, sym, text, "New Circle Text", false);
//Build geometry
Coordinate2D pt1 = new Coordinate2D(3.5, 7.5);
Coordinate2D pt2 = new Coordinate2D(4.16, 8);
Coordinate2D pt3 = new Coordinate2D(4.83, 7.1);
Coordinate2D pt4 = new Coordinate2D(5.5, 7.5);
var bez = new CubicBezierBuilderEx(pt1, pt2, pt3, pt4);
var bezSeg = bez.ToSegment();
Polyline bezPl = PolylineBuilderEx.CreatePolyline(bezSeg, AttributeFlags.AllAttributes);
ColorFactory.Instance.BlackRGB, 24, "Comic Sans MS", "Regular");
layout, TextType.SplinedText, bezPl, sym, "this is the bezier text",
"New Bezier Text", true, new ElementInfo() { Anchor = Anchor.CenterPoint });
//Build geometry
Coordinate2D center = new Coordinate2D(4.5, 2.75);
var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
var ellipse = eabElp.ToSegment();
PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
ColorFactory.Instance.BlueRGB, 10, "Arial", "Regular");
string text = "Ellipse, ellipse, ellipse";
GraphicElement ge = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.PolygonParagraph, poly, sym, text, "New Ellipse Text", false);
//Note: Needs QueuedTask to run
//using the default font
var textSym1 = SymbolFactory.Instance.ConstructTextSymbol();
var textSym2 = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.BlueRGB, 14);
//using a specific font
var textSym3 = SymbolFactory.Instance.ConstructTextSymbol("Arial");
var textSym4 = SymbolFactory.Instance.ConstructTextSymbol(
"Arial", "Narrow Bold");
//or query available fonts to ensure the font is there
var all_fonts = SymbolFactory.Instance.GetAvailableFonts();
var font = all_fonts.FirstOrDefault(f => f.fontName == "Arial");
if (!string.IsNullOrEmpty(font.fontName))
var textSym5 = SymbolFactory.Instance.ConstructTextSymbol(font.fontName);
//or with a font+style
var textSym6 = SymbolFactory.Instance.ConstructTextSymbol(
font.fontName, font.fontStyles.First());
//overloads - font + color and size, etc
var textSym7 = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.BlueRGB, 14, "Times New Roman", "Italic");
//custom symbol - black stroke, red fill
var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB),
SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1));
var textSym8 = SymbolFactory.Instance.ConstructTextSymbol(
poly_symbol, 14, "Georgia", "Bold");
