ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / ConstructTextSymbol Method / ConstructTextSymbol(CIMColor,Double,String,String) Method
ArcGIS.Core.CIM.CIMColor
The size of the text symbol to construct.
The font family name of the text symbol to construct.
The font style name of the text symbol to construct.
Example
    Constructs a default text symbol given its color, size, font family name and style. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function ConstructTextSymbol( _
       ByVal color As CIMColor, _
       ByVal size As Double, _
       ByVal fontFamilyName As String, _
       ByVal fontStyleName As String _
    ) As CIMTextSymbol
    Parameters
    color
    size
    fontFamilyName
    fontStyleName
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Remarks
    If the font family is null or does not exist the current default font family will be assigned. If the font style is null or does not exist, the default font style for the font family will be assigned.
    Example
    Create Point Text Element 1
      //Create a simple point text element and assign basic symbology and text settings.
      //Note: Must be on QueuedTask.Run
      //Build 2D point geometry
      Coordinate2D coord2D = new Coordinate2D(3.5, 10);
      //Set symbology, create and add element to layout
      CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
                    ColorFactory.Instance.RedRGB, 32, "Arial", "Regular");
      string textString = "Point text";
      //use ElementInfo to set placement properties during create
      var elemInfo = new ElementInfo()
        Anchor = Anchor.CenterPoint,
        Rotation = 45
      var ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.PointText, coord2D.ToMapPoint(), sym, textString,
                           "New Point Text", true, elemInfo);
      //Change additional text properties
      ptTxtElm.SetX(4.5);
      ptTxtElm.SetY(9.5);
    Create Rectangle Paragraph Text Element 1
      //Create rectangle text with background and border symbology.
      //Build 2D polygon geometry
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(3.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 7));
      plyCoords.Add(new Coordinate2D(4.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.7));
      plyCoords.Add(new Coordinate2D(5.5, 6.1));
      plyCoords.Add(new Coordinate2D(3.5, 6.1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
      //Also notice how formatting tags are using within the text string.
                        ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
      string text = "Some Text String that is really long and is " +
                    "<BOL>forced to wrap to other lines</BOL> so that " +
                    "we can see the effects." as String;
      GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
        layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
      //(Optionally) Modify paragraph border
      CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
      CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
      cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
      cimPolyTxtGra.Frame.BorderSymbol.Symbol =
                   SymbolFactory.Instance.ConstructLineSymbol(
                              ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
      polyTxtElm.SetGraphic(polyTxtGra);
    Construct a Text Symbol With Options
        //Note: Needs QueuedTask to run
        //using the default font
        var textSym1 = SymbolFactory.Instance.ConstructTextSymbol();
        var textSym2 = SymbolFactory.Instance.ConstructTextSymbol(
                           ColorFactory.Instance.BlueRGB, 14);
        //using a specific font
        var textSym3 = SymbolFactory.Instance.ConstructTextSymbol("Arial");
        var textSym4 = SymbolFactory.Instance.ConstructTextSymbol(
                          "Arial", "Narrow Bold");
        //or query available fonts to ensure the font is there
        var all_fonts = SymbolFactory.Instance.GetAvailableFonts();
        var font = all_fonts.FirstOrDefault(f => f.fontName == "Arial");
        if (!string.IsNullOrEmpty(font.fontName))
            var textSym5 = SymbolFactory.Instance.ConstructTextSymbol(font.fontName);
            //or with a font+style
            var textSym6 = SymbolFactory.Instance.ConstructTextSymbol(
                                            font.fontName, font.fontStyles.First());
        //overloads - font + color and size, etc
        var textSym7 = SymbolFactory.Instance.ConstructTextSymbol(
                        ColorFactory.Instance.BlueRGB, 14, "Times New Roman", "Italic");
        //custom symbol - black stroke, red fill
        var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
          SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB),
          SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1));
        var textSym8 = SymbolFactory.Instance.ConstructTextSymbol(
                poly_symbol, 14, "Georgia", "Bold");
    How to apply a Text Symbol to label of a layer
      var cimMap = MapView.Active.Map.GetDefinition();
      CIMTextSymbol simpleTextSymbol = SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.GreenRGB, 8.5, "Corbel", "Regular");
      var lyrDefn = theLayerToLabel.GetDefinition() as CIMFeatureLayer;
      //Get the label classes - we need the first one
      var listLabelClasses = lyrDefn.LabelClasses.ToList();
      var theLabelClass = listLabelClasses.FirstOrDefault();
      //Place all labels horizontally
      theLabelClass.StandardLabelPlacementProperties.LineLabelPosition.Horizontal = true;
      //theLabelClass.MaplexLabelPlacementProperties.AlignLabelToLineDirection = true;
      //Set the label classes' symbol to the custom text symbol
      theLabelClass.TextSymbol.Symbol = simpleTextSymbol;
      lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
      theLayerToLabel.SetDefinition(lyrDefn);
      (theLayerToLabel as FeatureLayer).SetLabelVisibility(true);
    Requirements
