ArcGIS.Desktop.Mapping Namespace / UniqueValueRendererDefinition Class / UseDefaultSymbol Property
Example
    UseDefaultSymbol Property (UniqueValueRendererDefinition)
    Gets or sets a boolean to indicate that DefaultSymbol will be used to draw features whose values are not found in the values list.
    Syntax
    public bool UseDefaultSymbol {get; set;}
    Public Property UseDefaultSymbol As Boolean
    Remarks
    You should use this when there are more unique values that what you set as ValuesLimit.
    Example
    Use Arcade expression to create Class Breaks
      var usaStatesLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                     .FirstOrDefault(fl => fl.Name == "USA States");
      if (usaStatesLayer == null)
        return;
      await QueuedTask.Run(() =>
      //Create a color ramp from red to blue
      var colorRampForPopulation = ColorFactory.Instance.ConstructColorRamp(
            ColorRampAlgorithm.LinearContinuous,
            ColorFactory.Instance.RedRGB, ColorFactory.Instance.BlueRGB);
      //This Arcade expression categorizes the POP2000 field in the usaStates layer
      //into Low, Medium, and High values
      var arcade = @"if ($feature.POP2000 < 1000000)
                       {return ""Low"";}" +
                   @"else if ($feature.POP2000 >= 100000 && $feature.POP2000 < 5000000)
                      {return ""Medium""; }" +
                    @"else if ($feature.POP2000 >= 5000000)
                      {return ""High"";}" +
                    @"else{return ""NA"";}";
      //Create the Arcade expression info
      CIMExpressionInfo arcadeExp = new CIMExpressionInfo();
      arcadeExp.Expression = arcade;
      arcadeExp.ReturnType = ExpressionReturnType.Default;
      arcadeExp.Title = "State Population Categorized";
      arcadeExp.Name = "USA States Population 2000";
      //Each population category is assigned a color from the color ramp and symbolized on the map
      // using a unique value renderer
      var uvr_desc = new UniqueValueRendererDefinition()
        //ValueFields = new List<string> { "STATION" },
        ColorRamp = colorRampForPopulation,
        UseDefaultSymbol = true,
        ValuesLimit = 100,
        ArcadeExpression = arcadeExp.Expression
      //Create the renderer and assign it to the layer
      var renderer = usaStatesLayer.CreateRenderer(uvr_desc);
      usaStatesLayer.SetRenderer(renderer);
    Requirements
