ArcGIS.Desktop.TaskAssistant Namespace / TaskItemInfo Class / Name Property
Example
    Name Property (TaskItemInfo)
    Gets the name of the task item.
    Syntax
    Public ReadOnly Property Name As String
    public string Name {get;}
    Example
    Get Task Information - from a TaskProjectItem
      var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
      // if there isn't a project task item, return
      if (taskItem == null)
        return;
      string message = await QueuedTask.Run(async () =>
        bool isOpen = taskItem.IsOpen;
        Guid taskGuid = taskItem.TaskItemGuid;
        string msg = "";
        try
          TaskItemInfo taskItemInfo = await taskItem.GetTaskItemInfoAsync();
          msg = "Name : " + taskItemInfo.Name;
          msg += "\r\n" + "Description : " + taskItemInfo.Description;
          msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
          msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
          // iterate the tasks in the task item
          IEnumerable<TaskInfo> taskInfos = taskItemInfo.GetTasks();
          foreach (TaskInfo taskInfo in taskInfos)
            string name = taskInfo.Name;
            Guid guid = taskInfo.Guid;
            // do something
        catch (OpenTaskException e)
          // exception thrown if task file doesn't exist or has incorrect format
          msg = e.Message;
        catch (TaskFileVersionException e)
          // exception thrown if task file does not support returning task information
          msg = e.Message;
        return msg;
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
    Get Task Information - from an .esriTasks file
      // TODO - substitute your own .esriTasks file
      string taskFile = @"c:\Tasks\Get Started.esriTasks";
        string msg = "";
        try
          // retrieve the task item information
          //At 2.x -
          //TaskItemInfo taskItemInfo = await TaskAssistantModule.GetTaskItemInfoAsync(taskFile);
          TaskItemInfo taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          msg = e.Message;
          msg = e.Message;
        return msg;
    Requirements
