ArcGIS.Core.Data.DDL Namespace / FieldDescription Class / GetDomainDescription Method
The specific subtype code for the ArcGIS.Core.Data.Field's ArcGIS.Core.Data.Domain. This argument is optional. If it is not set or is set to null, the field's domain at the table level is returned.
    Gets the associated DomainDescription of the ArcGIS.Core.Data.Field at the table level if subtypeCode is not specified. Otherwise, gets the DomainDescription for the specific subtype code.
    Syntax
    Public Function GetDomainDescription( _
       Optional ByVal subtypeCode As Nullable(Of Integer) _
    ) As DomainDescription
    public DomainDescription GetDomainDescription(
       Nullable<int> subtypeCode
    Parameters
    subtypeCode
    Return Value
    The DomainDescription if one is assigned. Otherwise, null is returned.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
