ArcGIS.Core.Data.DDL Namespace / RelationshipClassDescription Class / RelationshipType Property
Example
    RelationshipType Property (RelationshipClassDescription)
    Gets the relationship type.
    Syntax
    public RelationshipType RelationshipType {get; set;}
    Public Property RelationshipType As RelationshipType
    Example
    Creating relationship class
      Task CreateRelationshipWithRelationshipRulesAsync(SchemaBuilder schemaBuilder) => QueuedTask.Run(() =>
        // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
        FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
        FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
        TableDescription buildingTypeDescription = new TableDescription("BuildingType",
          new List<FieldDescription>() { buildingType, buildingTypeeDescription });
        TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
        // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
        FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
        FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
        FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
        FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
          new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
          new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
        // Set subtype details (optional)
        featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
          new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
        FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
        // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
          "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
          RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
          RelationshipType = RelationshipType.Composite
        // Adding relationship rules for the 'Marketing' subtype
        relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
        schemaBuilder.Create(relationshipClassDescription);
        schemaBuilder.Build();
    Requirements
    ArcGIS Pro version: 3.1 or higher.
