ArcGIS.Core.Data.Mapping Namespace / CatalogDataset Class
Members
    Represents a catalog dataset. A catalog dataset is the container for item references, which are called catalog dataset items - not unlike raster references stored in a raster catalog
    Object Model
    CatalogDataset ClassInsertCursor ClassCatalogDatasetFeature ClassRowBuffer ClassUpdateCursor ClassDifferenceCursor ClassTable ClassDatastore ClassCatalogDatasetDefinition ClassEnvelope ClassFeatureDataset ClassJoin ClassRelationshipClass ClassRowCursor ClassSelection ClassRowCursor ClassContingencyValidationResult Class
    Syntax
    public sealed class CatalogDataset : ArcGIS.Core.Data.FeatureClass, System.IDisposable
    Public NotInheritable Class CatalogDataset
       Inherits ArcGIS.Core.Data.FeatureClass
       Implements System.IDisposable
    Remarks
    Catalog datasets function similarly to polygon feature classes, with some essential differences. When viewing the dataset's attribute table, each record is an item in the catalog dataset containing a reference to its data path. The Shape field includes the footprint geometry for each item. This means that all catalog dataset items must have a spatial geometry — you cannot add tables or table web layers to catalog datasets.
    The footprint envelopes all of the item's features, rasters, and so forth. Each footprint feature's attributes are properties specific to the purpose, scope, and validation status of each dataset item.You can add, update, and maintain your own fields and values in the dataset's attribute table, and establish a join or relate with other tables, but you cannot access or edit the attribute table of the containing footprint layer.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Dataset
             ArcGIS.Core.Data.Table
                   ArcGIS.Core.Data.Mapping.CatalogDataset
    Requirements
    ArcGIS Pro version: 3.1 or higher.
