var options = ApplicationOptions.SelectionOptions;
//Note: Run within a QueuedTask
var defaultColor = options.DefaultSelectionColor;
//Set the selection color to red
var color = options.SelectionColor as CIMRGBColor;
options.SetSelectionColor(ColorFactory.Instance.CreateRGBColor(255, 0, 0));
//Set the selection fill color and fill hatch
var defaultFill = options.DefaultSelectionFillColor;
var fill = options.SelectionFillColor;
var isHatched = options.IsSelectionFillHatched;
options.SetSelectionFillColor(ColorFactory.Instance.CreateRGBColor(100, 100, 0));
if (!isHatched)
options.SetSelectionFillIsHatched(true);
//Toggle the selection Chip and Graphic
var showSelectionChip = options.ShowSelectionChip;
options.SetShowSelectionChip(!showSelectionChip);
var showSelectionGraphic = options.ShowSelectionGraphic;
options.SetShowSelectionGraphic(!showSelectionGraphic);
//Get the value indicating whether to save the layer and standalone table selection with the map.
var saveSelection = options.SaveSelection;
options.SetSaveSelection(!saveSelection);
//Get/Set the selection tolerance
var defaultTol = options.DefaultSelectionTolerance;
var tol = options.SelectionTolerance;
options.SetSelectionTolerance(2 * defaultTol);
// extension methods available for selection methods and combination methods
var selMethod = options.SelectionMethod;
options.SetSelectionMethod(SelectionMethod.Contains);
var combMethod = options.CombinationMethod;
options.SetCombinationMethod(SelectionCombinationMethod.Add);
// note that the following SelectionCombinationMethod is not supported
//options.SetCombinationMethod(SelectionCombinationMethod.XOR);
