ArcGIS.Desktop.Mapping Namespace / SelectionEnvironment Class / SetSelectionTolerance Method
The search tolerance in device units.
    SetSelectionTolerance Method (SelectionEnvironment)
    Sets the search tolerance in device units. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public static void SetSelectionTolerance(
       int tolerance
    Public Shared Sub SetSelectionTolerance( _
       ByVal tolerance As Integer _
    Parameters
    tolerance
    Exceptions
    ExceptionDescription
    Requirements
