//Selection tolerance for the map in pixels
var selectionTolerance = SelectionEnvironment.SelectionTolerance;
await QueuedTask.Run(() =>
//Get the map center
var mapExtent = mapView.Map.GetDefaultExtent();
var mapPoint = mapExtent.Center;
//Map center as screen point
var screenPoint = mapView.MapToScreen(mapPoint);
//Add selection tolerance pixels to get a "radius".
var radiusScreenPoint = new System.Windows.Point(screenPoint.X + selectionTolerance, screenPoint.Y);
var radiusMapPoint = mapView.ScreenToMap(radiusScreenPoint);
//Calculate the selection tolerance distance in map units.
var searchRadius = GeometryEngine.Instance.Distance(mapPoint, radiusMapPoint);
