ArcGIS.Core.Data Namespace / SelectionType Enumeration
Example Example
    Specifies the type of the selection.
    Syntax
    Members
    MemberDescription
    GlobalID A selection based on global ID.
    ObjectID A selection based on object ID.
    Example
    Selecting Rows from a Table
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
          QueryFilter anotherQueryFilter = new QueryFilter { WhereClause = "FLOOR = 1 AND WING = 'E'" };
          // For Selecting all matching entries.
          using (Selection anotherSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Normal))
          // This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the criteria is selected.
          using (Selection onlyOneSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
          // This can be used to obtain a empty selection which can be used as a container to combine results from different selections.
          using (Selection emptySelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Empty))
          // If you want to select all the records in a table.
          using (Selection allRecordSelection = enterpriseTable.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
    Selecting Features from a FeatureClass
        using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
          List<Coordinate2D> newCoordinates = new List<Coordinate2D>
            new Coordinate2D(1021570, 1880583),
            new Coordinate2D(1028730, 1880994),
            new Coordinate2D(1029718, 1875644),
            new Coordinate2D(1021405, 1875397)
          SpatialQueryFilter spatialFilter = new SpatialQueryFilter
            WhereClause = "FCODE = 'Park'",
            FilterGeometry = new PolygonBuilderEx(newCoordinates).ToGeometry(),
            SpatialRelationship = SpatialRelationship.Crosses
          using (Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal))
          // criteria is selected.
          using (Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
          // This can be used to obtain an empty selction which can be used as a container to combine results from different selections.
          using (Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty))
          using (Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Core.Data.SelectionType
    Requirements
