Return Value
The Table which corresponds to the
origin table of the join.origin table used to create the join. This method must be called on the MCT. Use QueuedTask.Run.origin table of the join.| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// GetDefinitionFromLayer - This code works even if the layer has a join to another table
//Must be called within QueuedTask.Run()
TableDefinition GetDefinitionFromLayer(FeatureLayer featureLayer)
// Get feature class from the layer
FeatureClass featureClass = featureLayer.GetFeatureClass();
// Determine if feature class is a join
if (featureClass.IsJoinedTable())
// Get join from feature class
Join join = featureClass.GetJoin();
// Get origin table from join
Table originTable = join.GetOriginTable();
// Return feature class definition from the join's origin table
return originTable.GetDefinition();
return featureClass.GetDefinition();
