ArcGIS.Core.Data Namespace / QueryTableDescription Class / PrimaryKeys Property
Example
    Gets or sets the comma-separated list of key fields to be used to manufacture ObjectIDs.
    Syntax
    public string PrimaryKeys {get; set;}
    Public Property PrimaryKeys As String
    Example
    Creating a QueryTable using a query which joins two versioned tables in a geodatabase
      await QueuedTask.Run(() =>
        QueryDef queryDef = new QueryDef
          Tables = "CommunityAddress JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
          SubFields = "CommunityAddress.OBJECTID, CommunityAddress.Shape, CommunityAddress.SITEADDID, CommunityAddress.ADDRNUM, CommunityAddress.FULLNAME, CommunityAddress.FULLADDR, CommunityAddress.MUNICIPALITY, MunicipalBoundary.Name, MunicipalBoundary.MUNITYP, MunicipalBoundary.LOCALFIPS",
        using (Geodatabase testVersion1Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
          AuthenticationMode = AuthenticationMode.DBMS,
          Instance = "instance",
          User = "user",
          Password = "password",
          Database = "database",
          Version = "user.testVersion1"
          QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef)
            Name = "CommunityAddrJounMunicipalBoundr",
            PrimaryKeys = testVersion1Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
          // Will be based on testVersion1.
          using (Table queryTable = testVersion1Geodatabase.OpenQueryTable(queryTableDescription))
            // Use queryTable.
        using (Geodatabase testVersion2Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
          User = "user",
          Version = "user.testVersion2"
            PrimaryKeys = testVersion2Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
          // Will be based on testVersion2.
          using (Table queryTable = testVersion2Geodatabase.OpenQueryTable(queryTableDescription))
            // Use queryTable.
    Requirements
