ArcGIS.Core.Data Namespace / SQLSyntax Class / GetProperty Method
A constant that specifies the type of SQL boolean property.
    GetProperty Method (SQLSyntax)
    Gets the boolean property corresponding to sqlProperty, e.g., SQLProperty.IsIdentifierCaseSensitive. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public bool GetProperty(
       SQLProperty sqlProperty
    Public Function GetProperty( _
       ByVal sqlProperty As SQLProperty _
    ) As Boolean
    Parameters
    sqlProperty
    Return Value
    The boolean value corresponding to sqlProperty.
    Exceptions
    ExceptionDescription
    sqlProperty is not a field of SQLProperty.
    A geodatabase-related exception has occurred.
    Requirements
