ArcGIS.Core.Data Namespace / SQLSyntax Class / GetSpecialCharacter Method
A constant that specifies a Datastore-dependent SQL special character.
    Gets the Datastore-dependent SQL special character corresponding to sqlSpecialCharacter, e.g., SQLSpecialCharacter.WildcardManyMatch. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetSpecialCharacter(
       SQLSpecialCharacter sqlSpecialCharacter
    Public Function GetSpecialCharacter( _
       ByVal sqlSpecialCharacter As SQLSpecialCharacter _
    ) As String
    Parameters
    sqlSpecialCharacter
    Return Value
    A Datastore-dependent SQL special character.
    Exceptions
    ExceptionDescription
    sqlSpecialCharacter is not a field of SQLSpecialCharacter.
    A geodatabase-related exception has occurred.
    Requirements
