ArcGIS.Core.Data Namespace / SQLSyntax Class / GetSupportedStrings Method
A constant that specifies the type of SQL string.
Example
    Gets all of the supported strings corresponding to sqlStringType, e.g., SQLStringType.InvalidCharacters. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public IReadOnlyList<string> GetSupportedStrings(
       SQLStringType sqlStringType
    Public Function GetSupportedStrings( _
       ByVal sqlStringType As SQLStringType _
    ) As IReadOnlyList(Of String)
    Parameters
    sqlStringType
    Return Value
    A IReadOnlyList of supported strings corresponding to sqlStringType.
    Exceptions
    ExceptionDescription
    sqlStringType is not a field of SQLStringType.
    A geodatabase-related exception has occurred.
    Example
    Searching a Table for non-Latin characters
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table table = geodatabase.OpenDataset<Table>("TableWithChineseCharacters"))
          // This will fail with many database systems that expect Latin characters by default
          string incorrectWhereClause = "颜色 = '绿'";
          // Correct solution is to prepend the 'National String Prefix' to the attribute value
          // For example, with SQL Server this value is 'N'
          // This value is obtained using the SQLSyntax class
          string nationalStringPrefix = "";
          SQLSyntax sqlSyntax = geodatabase.GetSQLSyntax();
          nationalStringPrefix = sqlSyntax.GetSupportedStrings(SQLStringType.NationalStringPrefix).First();
          // This Where clause will work
          QueryFilter queryFilter = new QueryFilter()
            WhereClause = "颜色 = " + nationalStringPrefix + "'绿'"
    Requirements
