ArcGIS.Core.Data Namespace / Table Class / GetControllerDatasets Method
Example
    Gets a IReadOnlyList of controller datasets of a specific Dataset type that this table or feature class participates in. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetControllerDatasets() As IReadOnlyList(Of Dataset)
    public IReadOnlyList<Dataset> GetControllerDatasets()
    Return Value
    A IReadOnlyList of controller datasets of a specific Dataset type that this table or feature class participates in.
    Exceptions
    ExceptionDescription
    This table does not support controller datasets.
    A geodatabase-related exception has occurred.
    Remarks
    If IsControllerDatasetSupported returns false, calling this method will result in an exception.
    Example
    Get parcel fabric from table
      var parcelFabricDataset = await QueuedTask.Run(() =>
        ParcelFabric myParcelFabricDataset = null;
        if (table.IsControllerDatasetSupported())
          // Tables can belong to multiple controller datasets, but at most one of them will be a parcel fabric
          IReadOnlyList<Dataset> controllerDatasets = table.GetControllerDatasets();
          foreach (Dataset controllerDataset in controllerDatasets)
            if (controllerDataset is ParcelFabric)
              myParcelFabricDataset = controllerDataset as ParcelFabric;
            else
              controllerDataset.Dispose();
        return myParcelFabricDataset;
    Get a Utility Network from a Table
      static UtilityNetwork GetUtilityNetworkFromTable()
        UtilityNetwork utilityNetwork = null;
        Table table = MapView.Active.Map.GetStandaloneTablesAsFlattenedList().First().GetTable();
        // This routine obtains a utility network from a table
          // Tables can belong to multiple controller datasets, but at most one of them will be a UtilityNetwork
            if (controllerDataset is UtilityNetwork)
              utilityNetwork = controllerDataset as UtilityNetwork;
            else
        return utilityNetwork;
    Get a Utility Network from a Layer
      static UtilityNetwork GetUtilityNetworkFromLayer(Layer unLayer)
        Layer layer = MapView.Active.Map.GetLayersAsFlattenedList().First();
        // This routine obtains a utility network from a FeatureLayer, SubtypeGroupLayer, or UtilityNetworkLayer
        if (layer is UtilityNetworkLayer)
          UtilityNetworkLayer utilityNetworkLayer = layer as UtilityNetworkLayer;
          utilityNetwork = utilityNetworkLayer.GetUtilityNetwork();
        else if (layer is SubtypeGroupLayer)
          CompositeLayer compositeLayer = layer as CompositeLayer;
          utilityNetwork = GetUtilityNetworkFromLayer(compositeLayer.Layers.First());
        else if (layer is FeatureLayer)
          FeatureLayer featureLayer = layer as FeatureLayer;
          using (FeatureClass featureClass = featureLayer.GetFeatureClass())
            if (featureClass.IsControllerDatasetSupported())
              IReadOnlyList<Dataset> controllerDatasets = new List<Dataset>();
              controllerDatasets = featureClass.GetControllerDatasets();
                else
    Requirements
