Return Value
true if this is a
joined table; otherwise, false.Table was obtained as a result of joining a Table or a FeatureClass with another Table or FeatureClass from the same or different Datastore. This method must be called on the MCT. Use QueuedTask.Run.joined table; otherwise, false.{
// GetDefinitionFromLayer - This code works even if the layer has a join to another table
//Must be called within QueuedTask.Run()
TableDefinition GetDefinitionFromLayer(FeatureLayer featureLayer)
// Get feature class from the layer
FeatureClass featureClass = featureLayer.GetFeatureClass();
// Determine if feature class is a join
if (featureClass.IsJoinedTable())
// Get join from feature class
Join join = featureClass.GetJoin();
// Get origin table from join
Table originTable = join.GetOriginTable();
// Return feature class definition from the join's origin table
return originTable.GetDefinition();
return featureClass.GetDefinition();
