ArcGIS.Desktop.Editing Namespace / MapTopologyProperties Class / Tolerance Property
Example
    Tolerance Property (MapTopologyProperties)
    Gets the topology tolerance. This value is in meters.
    Syntax
    Public Shadows ReadOnly Property Tolerance As Double
    public new double Tolerance {get;}
    Remarks
    If a user specified tolerance has been specified, then this value is returned, otherwise the tolerance is the same as the DefaultTolerance
    Example
    Get map topology properties
      // Retrieves the topology properties for the specified map asynchronously.
      var mapTopoProperties = await activeMap.GetTopologyAsync("Map") as MapTopologyProperties;
      var tolerance_m = mapTopoProperties.Tolerance;
      var defaultTolerance_m = mapTopoProperties.DefaultTolerance;
    Requirements
    ArcGIS Pro version: 3.1 or higher.
