ArcGIS.Core.Geometry Namespace / GeometryEngine Class / CalculateNonSimpleZs Method
The polygon or polyline to calculate Z-values for.
The value to which NaN Z-values that could not be interpolated will be set.
Example
    CalculateNonSimpleZs Method (GeometryEngine)
    Calculates Z attribute values for each non-simple (NaN) Z-value from existing simple (non-NaN) Z attributes on the specified geometry. The non-simple Z values are obtained by extrapolation/interpolation for polylines and interpolation for polygons.
    Syntax
    Public Function CalculateNonSimpleZs( _
       ByVal multipart As Multipart, _
       ByVal defaultZValue As Double _
    ) As Multipart
    public Multipart CalculateNonSimpleZs(
       Multipart multipart,
       double defaultZValue
    Parameters
    multipart
    defaultZValue
    Return Value
    A geometry in which each coordinate has a simple (non-NaN) Z value.
    Exceptions
    ExceptionDescription
    Multipart is null or empty.
    This geometry is not Z-Aware.
    Example
    Interpolate Z values on a polyline
      List<Coordinate3D> coords2 =
      new Coordinate3D(0, 0, 0),
      new Coordinate3D(0, 1000, double.NaN),
      new Coordinate3D(1000, 1000, 50),
      new Coordinate3D(1000, 1000, 76),
      SpatialReference sr = SpatialReferences.WebMercator;
      polyline = PolylineBuilderEx.CreatePolyline(coords2, sr);
      // polyline.HasZ = true
      // polyline.Points[1].HasZ = true
      // polyline.Points[1].Z  = NaN
      // polyline.Points[4].HasZ = true
      // polyline.Points[4].Z  = NaN
      Polyline polylineNoNaNZs = GeometryEngine.Instance.CalculateNonSimpleZs(polyline, 0) as Polyline;
      // polylineNoNaNZs.Points[1].HasZ = true
      // polylineNoNaNZs.Points[1].Z = 25  (halfway between 0 and 50)
      // polylineNoNaNZs.Points[4].HasZ = true
      // polylineNoNaNZs.Points[4].Z = 38  (halfway between 76 and 0)
    Requirements
