ArcGIS.Core.Geometry Namespace / GeometryEngine Class / SetConstantZ Method
The polygon or polyline to replace Zs.
The Z value to assign.
Example
    SetConstantZ Method (GeometryEngine)
    Replaces each Z value on the geometry with the specified Z-value.
    Syntax
    Public Function SetConstantZ( _
       ByVal multipart As Multipart, _
       ByVal zValue As Double _
    ) As Multipart
    public Multipart SetConstantZ(
       Multipart multipart,
       double zValue
    Parameters
    multipart
    zValue
    Return Value
    A geometry in which each coordinate has the specified Z-value. If the input multipart is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    Multipart is null.
    This geometry is not Z-Aware.
    Example
    Set all Zs in a polyline
      List<Coordinate3D> coordsZ =
        new Coordinate3D(1, 2, 3),
      new Coordinate3D(4, 5, 6),
      new Coordinate3D(7, 8, double.NaN)
      polyline = PolylineBuilderEx.CreatePolyline(coordsZ);
      // polyline.HasZ = true
      Polyline polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, -1) as Polyline;
      // polylineSetZ.Points[0].Z = -1
      // polylineSetZ.Points[1].Z = -1
      // polylineSetZ.Points[2].Z = -1
      polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, double.NaN) as Polyline;
      // polylineSetZ.Points[0].HasZ = true
      // polylineSetZ.Points[0].Z = NaN
      // polylineSetZ.Points[1].HasZ = true
      // polylineSetZ.Points[1].Z = NaN
      // polylineSetZ.Points[2].HasZ = true
      // polylineSetZ.Points[2].Z = NaN
      polylineSetZ = GeometryEngine.Instance.SetConstantZ(polyline, double.PositiveInfinity) as Polyline;
      // polylineSetZ.Points[0].Z = double.PositiveInfinity
      // polylineSetZ.Points[1].Z = double.PositiveInfinity
      // polylineSetZ.Points[2].Z = double.PositiveInfinity
    Requirements
