ArcGIS.Desktop.Core Namespace / IProjectWindow Interface
Members Example
    Use this interface to select items and retrieve the current selection
    Syntax
    Public Interface IProjectWindow
    public interface IProjectWindow
    Example
    Select an item in the Catalog pane
      //Get the catalog pane
      IProjectWindow projectWindow = Project.GetCatalogPane();
      //or get the active catalog view...
      //ArcGIS.Desktop.Core.IProjectWindow projectWindow = Project.GetActiveCatalogWindow();
      //eg Find a toolbox in the project
      string gpName = "Interacting with Maps.tbx";
      var toolbox = Project.Current.GetItems<GeoprocessingProjectItem>().FirstOrDefault(tbx => tbx.Name == gpName);
      //Select it under Toolboxes
      projectWindow.SelectItemAsync(toolbox, true, true, null);//null selects it in the first container - optionally await
                                                               //Note: Project.Current.GetProjectItemContainer("GP") would get toolbox container...
      //assume toolbox is also under Folders container. Select it under Folders instead of Toolboxes
      var foldersContainer = Project.Current.ProjectItemContainers.First(c => c.Path == "FolderConnection");
      //We must specify the container because Folders comes second (after Toolboxes)
      projectWindow.SelectItemAsync(toolbox, true, true, foldersContainer);//optionally await
      //Find a map and select it
      var mapItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(m => m.Name == "Map");
      //Map only occurs under "Maps" so the container need not be specified
      projectWindow.SelectItemAsync(mapItem, true, false, null);
    Requirements
