ArcGIS.Desktop.Mapping Namespace / LayerCreationParams Class / AutoZoomOnEmptyMap Property
    AutoZoomOnEmptyMap Property (LayerCreationParams)
    Gets and sets if the Map is zoomed to the layer extent if it is the first layer to be added.
    Syntax
    public new bool AutoZoomOnEmptyMap {get; set;}
    Public Shadows Property AutoZoomOnEmptyMap As Boolean
    Remarks
    The default value is true. This does not include base maps. It only affects the behavior of the map if this is the first (non-base map) layer being added. If it is set false it means that the map extent will not change (to the extent of the first layer being added)
    Requirements
    ArcGIS Pro version: 3.1 or higher.
