ArcGIS.Desktop.Mapping Namespace / MapMember Class / CanClearTime Method
    CanClearTime Method
    Gets if the mapMember supports time filtering and can clear the time filter. Clearing the time filter ensures that data is always shown. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CanClearTime() As Boolean
    public bool CanClearTime()
    Return Value
    True if the mapMember supports time filtering. False otherwise.
    Exceptions
    ExceptionDescription
    Remarks
    You should use this method before calling the ClearTime method.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
