ArcGIS.Desktop.Mapping Namespace / MapMember Class / IsTimeSupported Method
    Gets if time is supported for this mapMember. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function IsTimeSupported() As Boolean
    public bool IsTimeSupported()
    Return Value
    True if the mapMember supports time. false otherwise.
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.1 or higher.
