ArcGIS.Desktop.Mapping Namespace / TimeParameters Class / IsValid Method
    IsValid Method (TimeParameters)
    Gets if the time parameters are valid.
    Syntax
    Public Function IsValid() As Boolean
    public bool IsValid()
    Return Value
    True if valid. False otherwise
    Remarks
    The following outlines some of the rules for determining validity of the time parameters
    - if no StartTimeFieldName is specified, then a Start or End is required
    - TimeFormat must be a valid time format if specified. See GetSupportedTimeFormats.
    - if a TimeIntervalType is TimeIntervalType.Irregular, then a StartTimeFieldName is required.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
