ArcGIS.Desktop.Mapping Namespace / TopologyLayerCreationParams Class / AddAssociatedLayers Property
Example
    AddAssociatedLayers Property (TopologyLayerCreationParams)
    Gets and sets whether the topology associated layers are to be added along with the topology layer. Default value is true.
    Syntax
    Public Property AddAssociatedLayers As Boolean
    public bool AddAssociatedLayers {get; set;}
    Example
    Create TopologyLayer with an Uri pointing to a Topology dataset
        var path = @"D:\Data\CommunitySamplesData\Topology\GrandTeton.gdb\BackCountry\Backcountry_Topology";
        var lcp = new TopologyLayerCreationParams(new Uri(path));
        lcp.Name = "GrandTeton_Backcountry";
        lcp.AddAssociatedLayers = true;
        //Note: Needs QueuedTask to run
        var topoLayer = LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.TopologyLayer>(lcp, MapView.Active.Map);
    Create Topology Layer using Topology dataset
        //Get the Topology of another Topology layer
        var existingTopology = MapView.Active.Map.GetLayersAsFlattenedList().OfType<TopologyLayer>().FirstOrDefault();
        if (existingTopology != null)
            var topology = existingTopology.GetTopology();
            //Configure the settings for a new Catalog layer using the CatalogDataset of an existing layer
            var topologyLyrParams = new TopologyLayerCreationParams(topology);
            topologyLyrParams.Name = "NewTopologyLayerFromAnotherTopologyLayer";
            topologyLyrParams.AddAssociatedLayers = true;
            LayerFactory.Instance.CreateLayer<TopologyLayer>(topologyLyrParams, MapView.Active.Map);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
