ArcGIS.Core.Data.Raster Namespace / RasterDataset Class / GetBandByName Method
Name of a band in this raster dataset.
Example
    GetBandByName Method (RasterDataset)
    Gets a RasterBand from this raster dataset based on the band name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetBandByName( _
       ByVal name As String _
    ) As RasterBand
    public RasterBand GetBandByName(
       string name
    Parameters
    name
    Return Value
    The RasterBand from this raster dataset based on the band name.
    Example
    Access the bands in a raster dataset
      var count = rasterDataset.GetBandCount();
      RasterBand rasterBandByName = rasterDataset.GetBandByName(sBandName);
      var index = rasterDataset.GetBandIndex(sBandName);
      // Get a RasterBand from the raster dataset
      RasterBand rasterBand = rasterDataset.GetBand(0);
      // Get the RasterBandDefinition from the raster band.
      RasterBandDefinition rasterBandDefinition = rasterBand.GetDefinition();
      // Get the name of the raster band from the raster band.
      string bandName = rasterBandDefinition.GetName();
    Requirements
