ArcGIS.Core.Data.Raster Namespace / RasterDataset Class / GetBandCount Method
Example
    GetBandCount Method (RasterDataset)
    Gets the number of bands in this raster dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetBandCount() As Integer
    public int GetBandCount()
    Return Value
    An integer representing the number of bands in this raster dataset.
    Example
    Access the bands in a raster dataset
      var count = rasterDataset.GetBandCount();
      RasterBand rasterBandByName = rasterDataset.GetBandByName(sBandName);
      var index = rasterDataset.GetBandIndex(sBandName);
      // Get a RasterBand from the raster dataset
      RasterBand rasterBand = rasterDataset.GetBand(0);
      // Get the RasterBandDefinition from the raster band.
      RasterBandDefinition rasterBandDefinition = rasterBand.GetDefinition();
      // Get the name of the raster band from the raster band.
      string bandName = rasterBandDefinition.GetName();
    Requirements
