ArcGIS.Core.Data.Raster Namespace / RasterDatasetDefinition Class / GetBandCount Method
Example
    GetBandCount Method (RasterDatasetDefinition)
    Gets the number of bands in the raster dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetBandCount() As Integer
    public int GetBandCount()
    Return Value
    An integer representing the number of bands in the raster dataset.
    Example
    Get the raster dataset definition from a raster dataset
    await QueuedTask.Run(() =>
      RasterDatasetDefinition rasterDatasetDefinition = rasterDataset.GetDefinition();
      // access the dataset definition properties
      rasterDatasetDefinition.GetBandCount();
    Requirements
