ArcGIS.Core.Data.Raster Namespace / RasterStorageDef Class / GetPyramidLevel Method
    Gets the number of pyramid levels to be built from this raster storage definition.
    Syntax
    Public Function GetPyramidLevel() As Integer
    public int GetPyramidLevel()
    Return Value
    An integer representing the number of pyramid levels to be built from this raster storage definition.
    Remarks
    If you want the geodatabase to build full pyramid levels with appropriate levels, use a value of –1. If you do not want any pyramids to be built, use 0, or you can specify the level you see fit your dataset. By default, the geodatabase builds full pyramid levels.
    Requirements
