ArcGIS.Core.Data.Raster Namespace / RasterStorageDef Class / SetCompressionType Method
The RasterCompressionType to set.
Example
    Sets the RasterCompressionType of the raster to be stored on this raster storage definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetCompressionType( _
       ByVal compression As RasterCompressionType _
    public void SetCompressionType(
       RasterCompressionType compression
    Parameters
    compression
    Remarks
    The compression type property specifies the compression method to be used to compress the raster data to be stored. LZ77 (lossless) and JPEG (lossy), and JPEG 2000 compression types are supported. By default, the compression type is set to LZ77.
    Example
    Write a compressed image to a raster field
    await QueuedTask.Run(() =>
      //Open the raster dataset on disk and create a compressed raster value dataset object
      var dataStore = new ArcGIS.Core.Data.FileSystemDatastore(new ArcGIS.Core.Data.FileSystemConnectionPath(new Uri(@"e:\temp"), ArcGIS.Core.Data.FileSystemDatastoreType.Raster));
      using (var fileRasterDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Raster.RasterDataset>("Hydrant.jpg"))
        var storageDef = new ArcGIS.Core.Data.Raster.RasterStorageDef();
        storageDef.SetCompressionType(ArcGIS.Core.Data.Raster.RasterCompressionType.JPEG);
        storageDef.SetCompressionQuality(90);
        var rv = new ArcGIS.Core.Data.Raster.RasterValue();
        rv.SetRasterDataset(fileRasterDataset);
        rv.SetRasterStorageDef(storageDef);
        var sel = MapView.Active.Map.GetSelection();
        //insert a raster value object into the raster field
        var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
        insp.Load(sel.ToDictionary().Keys.First(), sel.ToDictionary().Values.First());
        insp["Photo"] = rv;
        var op = new EditOperation() { Name = "Raster Inspector" };
        op.Modify(insp);
        if (!op.IsEmpty)
          var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Requirements
