ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Clip Method
The geometry to be clipped by the given envelope.
A geometry that represents the area clipped by envelope.
Example
    Clip Method (IGeometryEngine)
    Constructs the polygon created by clipping geometry by envelope.
    Syntax
    Parameters
    geometry
    envelope
    Return Value
    The clipped geometry.
    Exceptions
    ExceptionDescription
    Either geometry or envelope or both are null or empty.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    If the input geometry is a multipatch, then the multipatch is projected to the 2D-plane. The output geometry will be a polygon.
    GeometryEngine Clip
    Example
    Clip a Polyline
      // clip a polyline by an envelope
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(2.0, 2.0, 4.0, 4.0);
      LineSegment line = LineBuilderEx.CreateLineSegment(new Coordinate2D(0, 3), new Coordinate2D(5.0, 3.0));
      polyline = PolylineBuilderEx.CreatePolyline(line);
      Geometry clipGeom = GeometryEngine.Instance.Clip(polyline, env);
    Clip a Polyline by a Polygon
      // clip a polyline by a polygon
      List<Coordinate2D> list =
        new Coordinate2D(1.0, 1.0),
        new Coordinate2D(1.0, 4.0),
        new Coordinate2D(4.0, 4.0),
        new Coordinate2D(4.0, 1.0),
      polygon = PolygonBuilderEx.CreatePolygon(list, SpatialReferences.WGS84);
      LineSegment crossingLine = LineBuilderEx.CreateLineSegment(MapPointBuilderEx.CreateMapPoint(0, 3), MapPointBuilderEx.CreateMapPoint(5.0, 3.0));
      Polyline p = PolylineBuilderEx.CreatePolyline(crossingLine);
      Geometry geometry = GeometryEngine.Instance.Clip(p, polygon.Extent);
    Requirements
